Help with my truck
I have a second generation Dodge ram truck with a 3.9 V6 it's a 01 model I replaced the air idle control cuz that's what it says but it still acts it still has a vacuum leak somewhere I've sprayed around vacuum lines or starter fluid trying to change the picture of the motor nothing can you tell me what can somebody help me I should say or guide me to what I need to do to fix it I just bought a new air control module is a ghost on the back of the throttle body I'm new to dodge and I know they're touchy any help or ideas would be great
I'd remove the throttle body and replace the base gasket for starters. In addition, I'd remove the idle air controller (IAC) in the rear of the throttle body and thoroughly clean the well that the IAC piston extends into. That well in the throttle body is famous for carbon accumulation over time and causes the engine to run erratically.
