98.5 Overhead Console
Old Oct 25, 2023 | 10:01 PM
Tad Wicks's Avatar
Tad Wicks
Default 98.5 Overhead Console
Question, 1998.5 3500 Sport Diesel. DRW 2WD I would like to install if possible the high rev overhead console with the temperature, time, compass and all the bells and whistles, I have the plain Jane. Has anybody done this? are the sensors mounted elsewhere? is the wiring already there? Just wondering. Thanks
Old Oct 25, 2023 | 10:18 PM
AtomicDog's Avatar
AtomicDog
There was another thread on this forum that discussed that issue a month or so ago. Try using the search feature to find it. From what I recall, it can be done, as the main wiring running up the pillar should be there. You would need to obtain the console and the wiring from the console to the connector in the pillar (if there, as it should be) and also check the radiator support for the temperature sender and wiring.
