OK got a 01 2500 when you go to take off you gotta go to the lowest gear and then shift back to drive im new to the Mopar family please any help would be great
Check to see if your electrical connector is plugged into the transmission or if there might be breached wiring in the harness. I believe the connector is an 8 wire harness.
