99 Ram 1500 crank / no start
Old Apr 6, 2024 | 10:45 AM
Patrick Culpepper's Avatar
Patrick Culpepper
Default 99 Ram 1500 crank / no start
I have a 99 Dodge ram 1500 4x4 5.2 . Was running fine , when I cut it off , now crank / no start . Please help. Thanks crank sensor replaced 4 years ago when I replaced flywheel , clutch disc , pressure plate , throw out bearing , clutch slave & master cylinder.
Old Apr 6, 2024 | 11:08 AM
AtomicDog's Avatar
AtomicDog
Did you replace the crank sensor with a Mopar crank sensor? I had a similar issue a couple of years ago. My Borg-Warner crank sensor started to cause periodic no starts that were hard to pin down. One day, the truck died while driving down the road and I had my scanner with me. The scanner code pointed to a crank sensor failure. Replaced it with a Mopar crank sensor and haven't had any further issues.
Old Apr 7, 2024 | 08:03 AM
Moparite's Avatar
Moparite
Check engine light on? Any codes?
Old Apr 9, 2024 | 04:13 PM
Patrick Culpepper
Just to confirm , just plain old fuel pump replacement. Way over thought. Said it was the fuel pump from the beginning , but had to eliminate all the B/S sensors first . LOL running like a champ now. Thanks everyone.
