01 5.2 crank no start
Old May 18, 2024 | 11:51 PM
Zulu's Avatar
Zulu
Default 01 5.2 crank no start
truck is a 2001 ram 1500 5.2 4x4 5 speed
about a month ago I was driving normally and the truck just puttered out, it restarted for probably 30 seconds after sitting for a second and a lot of cranking enough for me to get it off the road.
it won't start now and will only crank, i checked fuel pressure and it was good, i checked spark and its also good, asd relay was also checked and is functioning.
if i spray ether into it, it acts like it wants to fire but just won't.
could there be a sensor keeping it from running?
Old May 19, 2024 | 07:06 AM
Moparite's Avatar
Moparite
What psi? Did you check for any codes?
Old May 21, 2024 | 04:21 PM
Zulu's Avatar
Zulu
the fuel pressure was in the mid 40s, I haven't checked for any codes yet been busy working.
Old May 21, 2024 | 09:47 PM
dodgetruck2's Avatar
dodgetruck2
Would definitely check for codes, a check engine light would strongly indicate whether or not is could have codes stores. There's a magnetic pickup coil in the distributor for spark/injector timing.
