Halo wiring how-to?
Old Jul 24, 2024 | 05:10 PM
JCB.RAM's Avatar
JCB.RAM
Default Halo wiring how-to?
I've tried searching if there was discussion on this but had no luck.
Is there a how-to on installing halo headlamps and halo fog lights? I'm trying to figure out the best place to tap into the running lights so the halos come on with the (duh) running lights.
Do you tap into 2 of the 3 wires that go to the turn lamp? If so, which ones? (I have green / black+yellow / black)
Or, is there a better -- more correct way to do this?
Old Jul 24, 2024 | 05:59 PM
Moparite's Avatar
Moparite
Anyplace past the headlight switch and before the bulbs(running lights). Probably around the battery so you can wire up the rest. Tap into it to power a relay with it's own power from the battery. Then use that to power the halos.
