cranks a long time before starting
Old Jan 10, 2006 | 12:27 AM
tkrocks's Avatar
tkrocks
Default cranks a long time before starting
Has anybody solved this problem i have to crank engine a while before it fires i read it before but no solutins thanks for any help
97 1500 5.9 mag.
Old Jan 10, 2006 | 12:31 AM
rogerdoger's Avatar
rogerdoger
Default RE: cranks a long time before starting
got the same prob on a 98 5.2L
mine starts fine when cold but if it has been driven takes a long time. then finally kicks over
took it to dodge, and mech took a listen, said it could be fuel pump
Old Jan 28, 2006 | 06:28 PM
Johnnybangbang's Avatar
Johnnybangbang
Check your injectors I had to change one starts like a champ now
John
Old Feb 7, 2006 | 03:12 PM
Chopper1's Avatar
Chopper1
I had the same problem at about 60,000 miles. If I let off the key and tried again it would fire right up. Tried tune up with no luck. Went to dealer and they cleaned one of the injectors??. Within 2 months it would barely start to go to work. Managed to get it started at work and went straight to dealer. Was still under warranty. The fuel pump died 400 yards from dealer. Had to wait an hour and a half for dealers tow company to tow me within sight.
Would get fuel pump/pressure checked out.
Old Feb 7, 2006 | 03:46 PM
steve05ram360's Avatar
steve05ram360
problem is a check valve in the fuel pump assembly... turn the key on for 2 seconds & off and on for 2 seconds again, then try to start it. if it fires up every time, then your check valve in the pump is bad. it is there to keep fuel pressure up to help starting.
Old Feb 7, 2006 | 08:29 PM
Socha_62's Avatar
Socha_62
Thats what mine does! And no way in hell I'm diging into the gas tank [:'(]
Old Feb 7, 2006 | 08:47 PM
steve05ram360
ORIGINAL: Socha_62
lol come on... where's your sense of adventure? did you try it? (the key test)
Old Feb 8, 2006 | 12:23 AM
Socha_62's Avatar
Socha_62
I haven't done the key test. But it cranks for a long time, but if I let it crank for a few seconds, then stop, it starts right up.
How much am I looking at to fix it? Maybe I'll do it on the already growing Spring Break list
Old Feb 8, 2006 | 02:26 AM
shott8283's Avatar
shott8283
well define a long start... mine is hard to start when its wicked cold out... hard to start meaning it cranks but pretty slow and takesa bout 3 secons to fire ... when it firsts fires it takes abouta second to get up to idle... like a slow steady pace to from dead stop to idle..
but when its warm out (say above 40deg) its easy to start .. even if its first thing in the morning... i think its just b/c its a cold blooded b*tch
Old Feb 10, 2006 | 07:00 PM
rogerdoger's Avatar
rogerdoger
if i turn key to ignition so i hear the fuel pump kick in, and then off, and then i try to start it..... it works... but if i just try to crank right of the bat it turns fast but for like 5-8 seconds
