5.9 Magnum Engine
Old Oct 18, 2024 | 06:33 PM
Ruby5.9's Avatar
Ruby5.9
Default 5.9 Magnum Engine
Hey there everybody, I have a question to ask about the 5.9 magnums.. It's probably a dumb question but I am by no means a mechanic or anything... Are 5.9 magnums carbureted or are they fuel injected? I'm raising this question because I was looking at 360 magnum engines on eBay motors for shats and gaggles when I noticed the distributor cap.. which led me to believe that the engine is carbureted, but at the same time I've never taken a solid look into it even with my own truck. Something tells me it's not carbureted but I want to reach out here because I know somebody will have a definite answer. Thank you for reading and thank you for your time reader.
Old Oct 18, 2024 | 06:52 PM
dodgetruck2's Avatar
dodgetruck2
The magnum line starting in the late 80s is multi port fuel injection, meaning an injector in every hole. It does still run a distributor that has computer controlled spark timing.
Old Oct 18, 2024 | 10:51 PM
AtomicDog's Avatar
AtomicDog
Folks do modify and run carburetors on 5.9 magnum engines, as aluminum intake manifolds are readily available for them to accept a 4 barrel carburetor.
Old Oct 18, 2024 | 11:40 PM
ol' grouch's Avatar
ol' grouch
The Magnum engine came out in 1992 and are all fuel injected. I have seen carburetor intakes put on them to use a carburetor and the distributor can be changed to electronic ignition. In 1988, the LA engines got fuel injection but they weren't Magnums. The biggest difference from earlier engines was they had roller lifters.
At some point Chrysler changed how they are balanced. The 5.9 and 5.2 engines are balanced differently.
Old Oct 19, 2024 | 08:01 AM
Moparite's Avatar
Moparite
92 for the 318, 93 for the 360. The source of ignition has nothing to do with how an engine gets it's fuel. The later LA motors had throttle body injection which then went into sequential injection when the magnums came out. Both had distributors. As engines progressed they wanted to get rid of maintenance items(cap and rotor) that had to be changed periodically. Then engines where designed with a coil pack per cylinder and did away with the distributor. If you care to look magnum swap has a lot of info on the differences between the motors.
