1994 Dakota V6 No Heat
Old Jan 28, 2025 | 11:11 AM
Harryo75's Avatar
Harryo75
Default 1994 Dakota V6 No Heat
I have had system flushed replaced radiator(it leaked). New upper and lower hoses, new thermo what manual called for. I had some heat. Had water pumped replaced ( leaking) heater core flushed a few times, now i have no heat. Hose to heater core is hot, return hose is cold. any ideas, suggestions?
Old Jan 28, 2025 | 12:37 PM
AtomicDog's Avatar
AtomicDog
Sounds like you have a blockage at the heater core if one hose is hot and the other is cold. Sounds like the heater core still needs to be flushed some more..
Old Jan 28, 2025 | 07:39 PM
dodgetruck2's Avatar
dodgetruck2
Also possibly a blockage in the return hose. Remove the return hose from the core and see if it flows through. Assuming you did a flush I would think this would be confirmed already
Old Jan 29, 2025 | 12:43 AM
AtomicDog's Avatar
AtomicDog
Lastly, do you have a laser temperature gun? (here's an example - https://www.harborfreight.com/121-in...ter-63985.html)
If so, what are the temperature readings for the inlet and outlet heater core hoses?
Old Jan 29, 2025 | 10:02 PM
ol' grouch's Avatar
ol' grouch
Classic symptom of a clogged heater core. Unhook your hoses to the core. Press a garden hose into the cooler hose and reverse flow it. It's possible some gooky stuff (<--------fancy technical term) got loose and got in there. If you reverse flush the hoses, with the drain to the floor, not back into the engine, it may come loose.
