1996 Dodge ram 1500 5.2
Old May 8, 2025 | 04:39 AM
ChrisF.'s Avatar
ChrisF.
Default 1996 Dodge ram 1500 5.2 No Start Help!!
Recently I went off-road with the truck ran fine after till I pulled over and shut it off went back to crack and it wouldn’t crank no click no nothing ended up getting the truck towed back home and I started digging into it, thought it was the ignition switch because I had no power windows, blower motor, and no back up lights. Changed the switch out and when I went go crank it nothing went to test for power I was receiving 12v to the red wire and my dash would turn on and my radio but still no power windows nor blower motor or back up lights. So next thing I change was the neutral safety switch and still nothing so I went and changed my battery cables because they where all corroded and damaged and still nothing went to test grounds and the ground from the block to the fire wall was damaged so I changed it out and still nothing. I ended up seeing if I’m getting power to my relays and fuses and I was getting power to everything and no fuses looked blown. I took off the fuse box under the hood to see if a wire came undone or something but everything looked normal I put the old ground strap on and my power windows, blower motor and back lights started working but now my dash won’t light up nor my radio. Idk what it could be and im really needing help here to figure it out.
