Help 96 RAM 1500 crank no start
Old Aug 28, 2025 | 06:31 PM
mrelijahgardner's Avatar
mrelijahgardner
Default Help 96 RAM 1500 crank no start
A buddy and I picked up a non running project truck. It's a 96 RAM 1500. It's 5.9.
It cranks but doesn't really even try to start.
I've checked fuel at the rail and used starting fluid. I didn't use a fuel pressure gauge but I'm pretty confident fuel delivery is fine.
It has spark at the coil and the plugs. I kinda half assed set #1 to close-ish to TDC. The rotor button looked pretty far off. We moved the distributor a little to see if it works make a difference. It only made a minor difference. It's not doing much more than occasionally giving a half hearted burp of a sputter.
I was reading that the distributor position doesn't set the timing. Did I read something incorrect. That didn't make sense to me but what I read is the computer will adjust it.
Any suggestions at what I should try?
Old Aug 28, 2025 | 06:56 PM
Moparite's Avatar
Moparite
How old is the fuel in the tank? Are the plugs in it any good? I would check compression in all the cylinders. Turning the distributor does not adjust timing. But you should set it like this:
#1 cylinder TDC on the COMPRESSION stroke position the distributor like this.
This will set the fuel sync to where it should run.
Old Aug 28, 2025 | 10:13 PM
dodgetruck2's Avatar
dodgetruck2
Follow up after setting the distributor as posted above, as you have now officially messed up the fuel sync it will not start. Did it have a check engine light? fault codes? They're simple systems but even a simple cam/crank sensor issue can cause headaches. Are the plugs coming out wet? how does the electrode look?
