Truck dies randomly
Hey guys, as the title says, my truck dies randomly. It’s a 96 1500 automatic with the 318. It’s happened twice now, where I’m driving and it just totally cuts out like someone flipped a kill switch. It doesn’t sputter, it doesn’t lack power beforehand, nothing to indicate it’s going to die. I’m not sure if it’s related or not but starting a couple days before this started happening I can’t get my headlights to turn on unless I hold back the lever to keep my brights on. The first time it died I was able to push it into a parking lot and after about 30 minutes it started right back up like nothing happened, but the second time I had to have it towed home. Both drives were only about a mile or two and it’s pretty cold outside, so I don’t think it’s anything getting too hot. The second time was 2 days ago and today it started right up. There were a few days between the two times it died and it ran just fine those days. I can’t just keep getting stranded, but I’m at a loss here.
So take the plastic cover off the steering column and visually inspect the wiring connectors? I don’t have much experience with wiring, just a broke college student trying to save some money.
To add to what Moparite wrote, the older trucks also need the cam sensor (fuel sync in Dodge speak) to work. Both crank and cam sensor often fail when they get hot and then work again when cold.
My truck did the same thing and it was a crack sensor
So did mine. When it died on the road driving it one day, I just happened to have my code scanner with me and plugged it in. It produced a code at that time stating that I had an intermittent crank sensor. I disconnected and reconnected the battery and the truck restarted. Once I made it home, I ordered a new OE crank sensor. No problems since the crank sensor swap...
