On the lines of filling your oil filter - new product injects oil....
Thought someone might like this. I know Im looking into it.-----
The AMS-Oilerâ„¢ is an oil pre-charger that puts an end to dry-engine starting. Typically, an engine that sits idle for even a short period of time will operate relatively dry upon starting before oil is able to fully lubricate the system. In fact, the automotive industry estimates that up to 50 percent of engine bearing wear occurs during the starting process. Indeed, the superiority of AMSOIL motor oils minimizes start-up wear by clinging to the metal surfaces, but even more can be done to concentrate the oil on the critical wear areas in an engine. With the AMS-Oiler in place, 160 cubic centimeters of oil is injected directly on the engine bearings and other wear sensitive surfaces upon turning of the key, giving instant protection to vital engine component
http://www.amsoil.com/storefront/amk.aspx
DAMN YOU ZEEKXXX!!!!!!!!!! i already have such a bad dodge fever addiction that im broke and you have to show me something else im going to have to buy!
ORIGINAL: Koldkut
sounds kinda chalky to me. I want to see the bearing wear results over the period of 200,000 miles with and without that wallet opener.
