timing chain install
Old Jan 19, 2006 | 11:47 PM
Socha_62's Avatar
Socha_62
Default RE: timing chain install
Do a search here and you'll find lots about it.
Roughly it is a PCM reprogram that stops pinging. You loose lots of power and some MPG. If you have it there will be a sticker on your PCM that says something about a reprogram. I wanna say its only for 98's, but I could be wrong.
Old Jan 19, 2006 | 11:49 PM
ryans590's Avatar
ryans590
hmmm i have a 98 ill half to find out about this more ive never herd of it b4
Old Jan 30, 2006 | 03:46 AM
SST_Ram's Avatar
SST_Ram
The "death Flash" is the dealers attempt to band aid a problem. It basically retards the timing enough to reduce the ping, and also hurts some of your horsepower as well.
