318 Temp Fluctuates
I just bought a 97 1500, 318 with 100,000 KMS on it. Under normal driving my temp fluctuates. It never goes into the red, but it gets 3/4 of the way there before the thermostat opens and the temp drops back to normal. I've had a couple of 318s in the past and don't remember them doing this. I had the rad flushed the other day, am I right in suspecting the thermostat should be changed? Is this normal or is there something else I should check?
Thanks in advance!
Thanks in advance!
Thermo controls engine temp, so that'd be the problem most likely. Maybe whoever you got it from but a hotter temp thermo in there, but I doubt it.
Change the thermo and see if that solves the problem
ORIGINAL: Socha_62
ORIGINAL: Drifter97
My coolant and overflow were rust colored so I flushed it, and 3 days later is was rust colored again. Do I just need to flush it again, or does that indicate a bad water pump or something??
