5.2L is ripping through fuel..$25 in a night...causes?
RE: 5.2L is ripping through fuel..$25 in a night...causes?
Will your truck give you the code if you turn the ignition on off on off on off on or whatever its flip it 3 times and the digital odometer reads the code on mine then you can post it up to see what it is. I'm not sure if a 98 will do that or not.
