Ok, any Ideas People?
Old Feb 8, 2006 | 02:32 AM
highline95jl's Avatar
highline95jl
Default Ok, any Ideas People?
Ok right now my moms demoing a late 90s 1500 Laramie Extended Cab with the Magnum V8. The thing has a problem with running apparently because well it dies constantly.
The thing stops running while moving. It barely made it in the driveway tonight. I was thinking it could be a bad battery or ulternator. Maby even something to do with the PCM. But I havent had time to go outside and run codes yet but everytime it dies right after it goes out every, and I mean every dummy light comes on. Thats what made me think it might be the PCM. Oh well what do you think gang?
Old Feb 8, 2006 | 02:45 AM
shott8283's Avatar
shott8283
Default RE: Ok, any Ideas People?
just dies when cruising down the road? maybe a fuel pump problem... thinking that if the fuel pump is shorting out and failing at inconsistant times... next time you get a chance get them codes for us... thatll help wicked big time....
i need to stop using the word wicked...
Old Feb 8, 2006 | 02:58 AM
ryans590's Avatar
ryans590
yah your right shot that is some "wicked" typing lol
anyways i dont think its your bat or alt if look at the charge gage if its real low or real high (10 or below or highrer than 18) then your alt could be bad however if it was ither of these you would half to boost it if it was dead enuf to kill the moter and once you took the bost of it would dye or soon after
Old Feb 8, 2006 | 02:07 PM
steve05ram360's Avatar
steve05ram360
dying while driving comes from a couple of things... lack of fuel or spark. the fuel pump & regulator handle the flow and pressure and the crank position sensor and cam position sensors handle the timing of the spark (tells the PCM where the TDC for each cylinder is).
There are 2 relays that could be a problem 1 being the fuel pump relay, and the other being the Auto Shutdown relay. in the 7 years i've had chrysler products, neither of those 2 relays have ever failed and I have never heard of anyone mentioning that they had a bad relay causing any problems.
hope this helps...
Old Feb 8, 2006 | 04:13 PM
greenmachine's Avatar
greenmachine
Had the same experience but not in a Ram. The car would just die and all the idiot lights would be on. It ended up being fuel sensor relay. Hope it helps.
