lifts lower and upper control arms
i put a rough country 3 in suspention lift on my truck with 35 in tire and stock rims and i am rubbing on my lower control arm. now should i get longer control arms and if so what else do i have to replace when i get them. iif not what should i do to keep my tires from rubbing.
What size are your tires? 35" x --"?
Or P---/-- R16?
Did you have the 35s on before the lift? Did they rub?
My guess right now is that your tires are too wide. You'd need to get a rim with less positive offset.
Or P---/-- R16?
ORIGINAL: Milfs98Dram
thanks so you just think different rims and offset it to the outside of the truck. 35 75 r16 is what i have know
But yeah, it sounds like your tires are much too wide for the stock rims. [>:]
