Foamy PS fluid?
Old Feb 18, 2006 | 12:28 PM
elkaholic's Avatar
elkaholic
Default Foamy PS fluid?
The power steering fluid was foamy when I checked it last night in my '01 2500 CTD. It's been cold here in CO, any ideas why this is happening? I need to fix this ASAP.
Thanks,
elkaholic
Old Feb 18, 2006 | 02:17 PM
Socha_62's Avatar
Socha_62
Default RE: Foamy PS fluid?
Is it ATF or Mopar PS fluid in it?
Old Feb 18, 2006 | 04:28 PM
ryans590's Avatar
ryans590
was it cold or hot wen you cheched it (as in the truck) if it was hot and just being used then some fomey is ok
Old Feb 18, 2006 | 06:28 PM
shott8283's Avatar
shott8283
foam in any kind of oil base liquid is usually a sighn of air or water trapped in there somewhere... some foam is normal.. do you go wheelin at all? if not or normally a dd.. then you should be fine.
Old Feb 18, 2006 | 11:53 PM
zipper's Avatar
zipper
Either water got in it or it is atf...many people just put atf in it because someone told them they could. You can but it foams up and is not good for the pump.
Old Feb 19, 2006 | 03:15 AM
MGDMike's Avatar
MGDMike
I'd check for that air leak.. this doesn't sound good.
