T-Max Winches ?
Old Feb 19, 2006 | 02:07 PM
venado's Avatar
venado
Default T-Max Winches ?
Guys
any comments on this T-max winches are they good in performance and durability
thinking about buying a winch but dont want to spend that much $$$
i was also checking on Mile Marker .
http://www.t-maxwinches.com/winches.htm
Old Feb 19, 2006 | 02:50 PM
ryans590's Avatar
ryans590
Default RE: T-Max Winches ?
ive never herd of them but as long as you get a big enuf one and dont over work it should be fine make shure you find out what the duty cycle is and dont exceed it also rember wen your stuck your pulling more than the weight of your truck employ the use of snach blocks wen nessaery. personally i wouldent get anything under 10000 lbs and find out what kind of warintee it has if its got a decent warrentee then that should be an indication it should be good. if you treat a winch right it shouldent give you any problems
