fitting 15" rims
Old Feb 20, 2006 | 07:46 AM
young buck's Avatar
young buck
Default fitting 15" rims
ok guys quick question
how much do i have to grind off of my calipers to fit 15" rims?
ive seen the same truck as mine with 15s but does it mess anything up as far as putting me in danger of not being able to stop?
Old Feb 20, 2006 | 02:18 PM
Socha_62's Avatar
Socha_62
Default RE: fitting 15" rims
Depends on the truck. What year? 1/2 or 3/4 ton? Tell us a bit about your ride.
Old Feb 20, 2006 | 04:49 PM
The Burning Rom's Avatar
The Burning Rom
Depends on the rim too. Some rims fit without grinding. Some you have to grind a bit off the caliper. Others you have to grind off of the caliper and the tie-rod end. There's really no way to tell without test fitting the rim first.
Old Feb 20, 2006 | 07:05 PM
young buck's Avatar
young buck
i have the 2000 off road 1500 and the rims are the rock crawler 15x10s
Old Feb 20, 2006 | 07:08 PM
young buck's Avatar
young buck
im really excited to give my truck the new look cant wait
Old Feb 20, 2006 | 07:17 PM
Socha_62's Avatar
Socha_62
Its hard to say like Rom said. Almost have to just order it and see if its fits.
Old Feb 20, 2006 | 08:12 PM
young buck's Avatar
young buck
already have them here and cant try that till this weekend and wanting to get a little heads up before starting so i can know what im up against here and how long it might take to do this
Old Feb 22, 2006 | 12:09 AM
mxmancr250's Avatar
mxmancr250
Plan on spending a good half hour grinding if you end up needing to. Even after you grind off enough material the clearance between the wheel and the caliper is extremely close and correct me if I am wrong but all it would take is to get a small rock jammed in there to cause problems. I sold my 15's and got some 17's instead.
Old Feb 22, 2006 | 12:17 AM
myblackram06's Avatar
myblackram06
i had 15 x 10 on my 1/2 ton and had no problems!!!!!
no grinding
Old Feb 22, 2006 | 12:21 AM
Tani1500's Avatar
Tani1500
i believe in 99 the switches to a bigger caliber so i dont think 15's will fit without massive grinding!
