96 Ram exterior light loss
Old Feb 20, 2006 | 09:18 PM
phathaw's Avatar
phathaw
Default 96 Ram exterior light loss
Hello all...I have an issue that I just can't seem to resolve. I currently have no exterior lights on my 96 Dodge Ram. I do have headlights, brake-lights, and turn signals. I dont have any top cab lights, no side lights, and no tail-lights. I've checked all fuses, relays, and bulbs that I know about. The lights will flash when security system is set. I appreciate all help that you can provide me with.
Old Feb 20, 2006 | 11:45 PM
ryans590's Avatar
ryans590
Default RE: 96 Ram exterior light loss
so in outher words all your lights are working excpt your park lights and they do work work wen the alarm goes off correct? well i can think of 2 things if you have checked all fuses and relays (not just ones marked lights check every single one and preffrabley with a multimeter) ither the light switch or your alarm (ithere where they spliced into your parklihgts has come loose or its something in the alarm its self) first of all it check the light switch pull your dash off and take out the switch still leaking it pluged in thow take a test light and test the wires 1 should go on and off with just the first pull of the switch (i cant rember the colour but if u look in a hayns/chiltem bool ittl tell you) if that tests out ok id have the alarm shop look at it and see if it is the alarm, how long have you had? it did u put it in your self?
Old Jun 9, 2007 | 01:26 AM
dazipman's Avatar
dazipman
I got the same problem, but i dont have an alarm and i just replaced the switch, butto no avail. Although my front parking lights work, the rear and third dont. Any help would be great.
