dropping drive shaft?
Old Feb 22, 2006 | 02:03 PM
bansheenut's Avatar
bansheenut
Default dropping drive shaft?
alright im in a delema with the pipes i have it wont fit around the front drive shaft. now i was wondering how to drop the front drive shaft it only has to come down in the front so i can fit the tubes around it... any info would be awsome... i got as far as taking the holder off with the 4 bolts... but it still seems like it locked in there....
Old Feb 22, 2006 | 02:18 PM
steve05ram360's Avatar
steve05ram360
Default RE: dropping drive shaft?
ok, so your truck is a 4x4... you need a custom y-pipe made at a shop... there are a few y-pipes out there but they are for the 2x4's only...
You will need to make sure the y-pipe doesnt interfere with the driveshaft when the axle moves...
as for the DS, it probably has some rust locking it in there, give it a whack with a rubber mallet to break it free. also check the manual (downloaded from the Merry Christmas thread at the top of the forum)
Old Feb 22, 2006 | 06:51 PM
Socha_62's Avatar
Socha_62
I agree with Steve, give her a good wack. Show it whos boss! But don't dent it, that'll screw the balance up.
Old Feb 22, 2006 | 06:53 PM
steve05ram360
actually you should wack it where the flanges meet and a rubber mallet wont hurt anything...
you could also spray some penitrating oil in there
Old Feb 23, 2006 | 01:43 AM
bansheenut's Avatar
bansheenut
so just unbolt those 4 bots and it should come off.. and yeah its a dodge ram but its for a newer one so it just doesnt want to fit in there but i know once its past the drive shaft then its golden. and yeah its hte 4x4
