Help on checking for plenum leak
Old Mar 3, 2006 | 10:57 PM
mugs's Avatar
mugs
Default Help on checking for plenum leak
To start out I am by no means mechanically inclined. With that being said, is checking for this leak something I can perform?
If so, where do I start?
What do I take off?
Any advice would be greatly appreciated.
Thanks,
Mugs
Old Mar 3, 2006 | 11:05 PM
Tani1500's Avatar
Tani1500
Default RE: Help on checking for plenum leak
go here it will tell you everything you need to know
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Mar 4, 2006 | 12:57 AM
garpoonga's Avatar
garpoonga
Also if you go to the DIY section, there is a great article by steveram00.
Old Mar 4, 2006 | 02:11 AM
shott8283's Avatar
shott8283
its not ahrd at all... if you got a 1/2" socket and socket wrench and the ability to pivot your elbow in a rotating motion then your set.. a monkey could do it...and id pay good money to see that!
Old Mar 5, 2006 | 11:26 AM
MikeNAmyS's Avatar
MikeNAmyS
Intake leak? I always use a can of ether(starting fluid).
Just spray around possible locations of the intake and if the engine RPMs go up, you found your leak!
