exhaust stinks!
Old Mar 10, 2006 | 12:34 AM
20dodgeram01's Avatar
20dodgeram01
Default exhaust stinks!
i've been noticing that my truck has a very nasty stench to it.. and it has a little bit of a rough idle which may have just been caused by the hypertech.. but if i watch the rpm gage i can see it wobble back and forth.. but what does it usually mean if your exhaust stinks?
Old Mar 10, 2006 | 12:56 AM
1996ramkid's Avatar
1996ramkid
Default RE: exhaust stinks!
like rotten eggs? if it's like eggs then you might have a bad cat because thats what mine smelled like
Old Mar 10, 2006 | 01:20 AM
20dodgeram01
yeah something like that.. im sure this is the stock cat with it and their known for going bad
Old Mar 10, 2006 | 04:09 AM
shott8283's Avatar
shott8283
get it checked out asap... clogged cat could seriously end up in some damge to the heads...
check out my post i just poped for this dude with header problems.. i explain a simple test that you can do yourself to give you an idea if theres a problem with the cat before getting charged by a shop
https://dodgeforum.com/m_414524/tm.htm
