Electrical Help.
Old Mar 14, 2006 | 05:16 PM
brightspark's Avatar
brightspark
Default Electrical Help.
Hi All, My freind has a 2000, Dodge Ram 2500 5.9TD and has stupidly reversed the jumper leads while trying to start the vehicle, I being a freind and also an autoelectrician have been stuck in the frame to sort out this problem. The dynamo has been tested and is fine although there seems to be a dead short when trying to re-connect the now fully charged batteries which is blowing the main fuse. Being in Scotland, UK, and with no wiring schematic I was wondering if anyone here would be able to help? Thanks for looking.
Old Mar 14, 2006 | 11:59 PM
ryans590's Avatar
ryans590
Default RE: Electrical Help.
welcome to DF!!
go here https://dodgeforum.com/m_340929/tm.htm and click on the link on the first post its a factory service manual for an 01 (should be almost identical for an 00) compleat with all schematics. what is a dynamo? i havent herd this term before. was the truck running wen the cables were looked up wrong? if so check the alt could have cooked it also im shure since your an autoelectrician you have checked all the grounds right as well as the main power leadsd
