throttle body spacer UNinstall
Old Mar 19, 2006 | 05:15 AM
radwebster's Avatar
radwebster
Default throttle body spacer UNinstall
previous owner had added a throttle body spacer to the truck...i have read the info on these things, looked like alot of people lost power and MPG's. i would prefer to change it back to stock. i haven't taken a close look at it yet but, has anyone installed one of these things? and if so, is it worth the effort to remove it, or should i just leave that little red crapper in there?
Old Mar 19, 2006 | 10:27 AM
Socha_62's Avatar
Socha_62
Default RE: throttle body spacer UNinstall
I would remove it myself, just because its so easy mostly.
To remove it take off your air cleaner and take the 4 screws on top of the TB off. and slide it out.
Old Mar 19, 2006 | 12:49 PM
radwebster's Avatar
radwebster
thanks. is that the only piece that goes with it, just that ring? do i need to do anything else to get it back to stock?
Old Mar 19, 2006 | 04:45 PM
JustinJohnson86's Avatar
JustinJohnson86
I would also buy a fastman TB =) I dont have one personally but by god im getting some money up for one hehe
Old Mar 19, 2006 | 05:35 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: radwebster
You may need to get a stock set of bolts...the ones that hold it on. IIRC, spacers come with longer bolts because...well...they add space and the stock ones wouldn't be long enough to go through both the TB and the spacer. You may be able to make it work with the longer ones though.
