finger tight!!!!!
Old Mar 20, 2006 | 03:22 AM
tib2001's Avatar
tib2001
Default finger tight!!!!!
so my 4wd shifter has felt kinda clunky.
and the dealer I bought the truck from, did not even try to detail the truck. it was a mess inside.
so today I pulled up the 4wd boot to see what went into taking off the shifter so I could clean the boot/shifter.
The bolts that hold the shifter on, were so loose I undid them with a loose finger grip.
guess that solves the 4wd problem
can I use loctite on these ???
Old Mar 20, 2006 | 03:30 AM
citygasdude's Avatar
citygasdude
Default RE: finger tight!!!!!
Dont know if you can use locktite or not but there are different formulas available, just make sure you dont get the strength that requires a torch to remove, lol
[IMG]local://upfiles/31643/177EDDD077B544B08C10D071717391A8.jpg[/IMG]
Old Mar 20, 2006 | 07:43 PM
crazy1snow's Avatar
crazy1snow
you can use the locktite as long as it doesn't come into contact with any fluids aka tranny fluid, gas, that kind of thing.
locktite is a funny thing, people think you need to coat the bolt with the stuff you really don't even need a drop of it. barely any works just as well as dipping the bolt in it.
Old Mar 21, 2006 | 01:58 AM
radwebster's Avatar
radwebster
ORIGINAL: crazy1snow
agreed, if you look at most bolts that come with a form of loctite on them on most products, there is just a light strip of it down the side
