Spark Plug Wire Order
Old Mar 23, 2006 | 07:29 AM
Sehr916's Avatar
Sehr916
Default Spark Plug Wire Order
Hi, I was replacing my plugs and wires and was hoping someone could give me a picture or diagram or link where i can see the correct order for the wires to make sure i did it correctly. Thanks
Old Mar 23, 2006 | 10:58 AM
MikeNAmyS's Avatar
MikeNAmyS
Default RE: Spark Plug Wire Order
Firing order is 1-8-4-3-6-5-7-2
Looking down on the cap on the PASSENGER side there is a hold down screw
The terminal to the front of that screw is #1 and you go CLOCKWISE.
[IMG]local://upfiles/30522/33394C8524274DABA17D1EC7BE5B872B.jpg[/IMG]
Old Mar 23, 2006 | 05:37 PM
Sehr916's Avatar
Sehr916
Thanks that helped a lot and the truck is running awesome. Didnt think some new MSD wires and new plugs would make a difference. The ones i pulled out from the previous owner are those weird Bosch 4 electrode plugs. Thanks!
Old Mar 24, 2006 | 02:53 PM
hometheaterman's Avatar
hometheaterman
I feel cheated now I didn't notice a differnce when changing to MSD wires. I had Champion plugs and stock wires before this. I think mine just wern't too bad before.
Old Mar 24, 2006 | 06:30 PM
Sehr916's Avatar
Sehr916
Im at 105000 miles with stock wires and those cr*p plugs that were probably replaced back at 30000. Thats why i think i noticed such a difference.
Old Jul 24, 2006 | 05:22 AM
kane.ram's Avatar
kane.ram
ORIGINAL: MikeNAmyS
Is that diagram true for the 5.2L as well? Including the cylinder order. I thought cylinder #1 was on the passenger side.
Old Jul 24, 2006 | 06:23 AM
The Burning Rom's Avatar
The Burning Rom
Nope...#1 is on the driver side.
That diagram is true for the 318 (5.2L), which also has the same firing order.
Old Jul 24, 2006 | 01:51 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Gotta watch the routing so as not to create a misfire. There was a TSB for the 5.2L engines a while back. Check out this link and print out the instructions.
http://autorepair.about.com/library/faqs/bl654h.htm
