5.9L Magnum V8 into Jeep wrangler, help!
Old Mar 29, 2006 | 03:20 AM
allamericanjeep's Avatar
allamericanjeep
Default RE: 5.9L Magnum V8 into Jeep wrangler, help!
Wow, thank you sooooo much! I had no idea that the PS pump was that much bigger than mine. I'll have to use that pump, it should owkr with my steering box. . .
i think i am going to fabricate my own brackets though, i think it will be cheaper and help me with hood clearance.
if you dont mind you think you could snap a couple more? motor mounts, throttle sensors, and the piece that bolts to the throttle and how it attatches? Thanks a TON!!!
Chris
more pics soon
Old Apr 1, 2006 | 08:19 PM
allamericanjeep
heres a big one. my wiring harness doesnt have the injectors labeled. Can anyone take a picture or decribe which one goes on which cylinder? The stock wiring loom is still on there so i should be able to decipher from a picture.
THANK YOU for all your help guys
Chris
Old Apr 2, 2006 | 01:12 AM
Socha_62's Avatar
Socha_62
Sorry it took so long I forgot to post the pics
Anyways here are some of the ones you asked for last time.
Motor Mounts, Passenger and Driver side.
Also not to sure what your talking about when you say the peice that bolts to the TB. Do you mean the part thats attaches the cables? If so buy a Fastman TB, great for performance and they have that part already on there (I think at least) You also said that you wanted to fab up your own bracket (the green one I outlined in the last pictures) and I remember you asked where the alt goes. Well the alt bolts into that bracket, and there is another pully that goes on there for belt routing. I would recomend to go to a junk yard and find that bracket for no A/C because that would save you a HUGE headache, but thats just my 2 cents
As for the TB sensors, when you have the Tb on you intake (facing the correct way ) there are 3 sensors. On the front is the MAP sensor, on the drivers side is the throttle position sensor, and on the back is your idle air control motor. I can snap some more pics of those things if you need them!
[IMG]local://upfiles/8718/26B457A040594902AE40320C7883CFDE.jpg[/IMG]
[IMG]local://upfiles/8718/33110289EA0B408FA4C264488BEED129.jpg[/IMG]
[IMG]local://upfiles/8718/81F83B1C61DB4EFF880C755AEE2F70F9.jpg[/IMG]
Old Apr 2, 2006 | 04:33 AM
allamericanjeep
hey man, thank you so much. i can't tell you how much you are helping me out with these pics.
i took out my old drive train a couple days ago, and got my motor mounts from advance adapters.
today i converted my tranfer case from 21 spline to 23 (new front case).
i will be making the mounts for my radiator fans tomorrow and cutting out the old motor mounts.
anyways, thanks again and i will be sure to post up pics when i get around to something good. . . (i.e. - getting the new motor in!)
but i did get a dodge keychain today!!!!
anyways thanks again, ill let you know how it goes
Chris
ps- if you could snap some of the injectors and the wire harness for them and their location that would be crucial. Thanks again
Old Apr 2, 2006 | 05:08 PM
ljpierce_ely's Avatar
ljpierce_ely
You said you wanted a service manual. Look at the top of the 2nd Gen Ram forum for the thread that says Merry Christmas Guys.
You will find a link to a service manual. It is in PDF format, is about 80 MB in size, and when you open it up in Acrobat, it has over 2800 pages of information!!
It is for a 2000 Ram, but what the hell. Should work fine for alot of what you are doing. And good luck with your changeover!
Old Apr 2, 2006 | 05:47 PM
allamericanjeep
thanks, i already got that one! i do need a pre 2000 one though for wiring as the wiring is different in that service manual than for the 1999 (and earlier)
thanks though!!
new pics coming soon
Chris
Old Apr 24, 2006 | 01:43 AM
allamericanjeep
its coming along. . .
Old Apr 24, 2006 | 01:49 AM
shott8283's Avatar
shott8283
lol...i think thats the biggest picture ive seen posted here yet!!!!
looks great dude!!!!!
that reminds me i need to get a cherry picker
Old Apr 24, 2006 | 02:06 AM
allamericanjeep
i need a 1998-2000 dodge ram FSM (.pdf) so bad it HURTS!!!! someone help!
Old Apr 24, 2006 | 02:25 AM
allamericanjeep
this ones bigger
lol
"how many horses you got in that thing"
"none, but i got a jack *** and 150 amps!"
