Help on installing SUPE COIL
Old Mar 24, 2006 | 05:56 PM
bigblueram's Avatar
bigblueram
Default Help on installing SUPE COIL
HI there sorry for the stupid question. How do you install the Accel super coil. Well the thing i really need to know is what goes in the tower. it sais the COIL HIGH VOLTAGE WIRE. is it just the one that goes from the original coil to the distributor if so do i need to cut the tip or something. if any of u have pics it would help more thank you. i have a 1994 dodge ram 5.2, 8.8mm wires, accel cap and rotor, headers, flomaster dual exhaust lifted 6" with 36 swampers. i only use this baby for mud races. and i really need to get this in there by sunday, thanx
Old Mar 24, 2006 | 06:22 PM
shott8283's Avatar
shott8283
Default RE: Help on installing SUPE COIL
the coil will have one large connector on it for the coil plug wire (goes to the distributor) and then there should be two small posts to out the terminal on like this
Green/Orange will be postive
Black will be negative
read through his DIY i did... i did it with a MSD system but should still be applicable to your needs
https://dodgeforum.com/m_405881/tm.htm
[IMG]local://upfiles/3936/544D0B6CC1D44F3E83BC357794266984.jpg[/IMG]
[IMG]local://upfiles/3936/3129F9C73F8A4D3CBBCD56015DCDF0CF.jpg[/IMG]
