head light probs need help
Old Mar 28, 2006 | 01:07 PM
88406vette's Avatar
88406vette
Default head light probs need help
In my 02 the lowbeams will sometimes not turn on but high beams have no prob. is there a relay that is gone or switch. I know this has to be a common prob cause my 01 had the same prob
Old Mar 28, 2006 | 01:54 PM
ryans590's Avatar
ryans590
Default RE: head light probs need help
id say you have a bad dimmer switch if you wiggle it do they come on? also check your grounds but high and low use a comon groung so i dont think it would be that but check it anyways
Old Mar 28, 2006 | 02:03 PM
mopowar's Avatar
mopowar
I have the same problem from time to time. When you say dimmer switch, do you mean the high/low switch on the turn signal?
The biggest PITA about this problem is that it only happens every once and a while and I always notice it at night when I really don't feel like screwing with it.
Old Mar 28, 2006 | 02:18 PM
ryans590's Avatar
ryans590
yes the dimmer switch as in the signal combo switch on the steering coloum, there is contacts in it that can ware out from use but you half to change the whole switch to change them if you take off your steering colom cover youll see the rest of it its aucluallu quite big
