Spark plug gap with new wires?
Old Mar 28, 2006 | 04:59 PM
Dodgeguy4x4's Avatar
Dodgeguy4x4
Default Spark plug gap with new wires?
I Just got new MSD 8.5mm super conductor wires and i was wondering what the stock gap should be and what i could put it up to with the new wires also is there any benifits of this or any dangers? o and its an 01 1500 5.9 360 THANKS GUYS!!!
Old Mar 28, 2006 | 05:07 PM
Racinfan83's Avatar
Racinfan83
Default RE: Spark plug gap with new wires?
I have mine set at .040. I believe stock spec is .035 to .040.
Old Mar 28, 2006 | 05:08 PM
young buck's Avatar
young buck
i believe it can be set at 60 after the msd stuff
Old Mar 28, 2006 | 05:10 PM
Dodgeguy4x4
What do you think of the wires? worth it?
Old Mar 29, 2006 | 12:57 AM
Sehr916's Avatar
Sehr916
I just put in new plugs and the Super Conducter wires and am also wondering if I was supposed to change the stock gap of .040 to something else, thanks!
Old Mar 29, 2006 | 01:29 AM
The Burning Rom's Avatar
The Burning Rom
Unless you go with an aftermarket coil or ignition, I would stick with the stock plug gap, which is 0.040
Old Mar 29, 2006 | 01:30 AM
ryans590's Avatar
ryans590
ive never herd much about pepole opening it up much i usally say stick around the .040 mark but i dont know if there is any diffrence with the msd setup
Old Mar 29, 2006 | 02:22 AM
Chopper1's Avatar
Chopper1
Wires will not create the need for added spark gap. The hotter and longer spark from an aftermarket coil and ignition system will.
Here is a couple of comments from the MSD tech forum. This was in referance to our Dodge trucks with an MSD ignition system.
You want to use a standard copper spark plug with the MSD system in place. Do not run a platinum plug or it can cause problems. Run a
copper plug one to two heat ranges colder than stock and gap them about 0.045â€.
The main determining factor for gapping a spark plug is the compression ratio of the motor. Once you have determined this then you can properly gap your plugs. This chart is a good starting point:
COMPRESSION.......PLUG GAP
Up to 10:5:1.........0.040"-0.060"
10.5:1 - 13.0:1.....0.032"-0.040"
Above 13.0:1........0.025"-0.032"
We recommend using a standard copper plug, 1-2 heat ranges cooler than stock OE; we really have no preference for brands. Although we do suggest staying away from any "HYPE", platinum, or iridium type plugs. When you combine them with a CD type ignition, they can cause pre-ignition problems.
Old Mar 29, 2006 | 02:29 AM
Sehr916's Avatar
Sehr916
Thats only with the MSD ignition system right? Not for new wire? Thanks
