wheel bearing ??
Is the whole bearing not turning, or is it just stuck again. If it is a proper fit, the race does not move but the bearing does, If you have it on now and its froze up you may have a faulty bearing. You just use the silver anti seize where tha race sits, that all, grease pack the rest.
I got it on, it wasn't easy it did not just slide on, first I used sand paper then a little grease and a few hard taps with the hammer.... My ? is if I have to do the other side in the future is there a step by step process that I should use? Guy's I would not have been able to do this repair without the input from all of you.... A big thank's to the Forum!!!!!
ORIGINAL: sixerp
It should've pretty much just slid right on provided any rust/corrosion was removed and any nicks on the spindle were smoothed to not have sharp edges. I've done countless styles just like this, just not on a Ram 2wd before, and the new ones slide on like butter once the spindle is taken care of...I suppose you were the lucky one to get the 1 in 1,000, p.i.t.a. one.
Glad to have helped.
Oh, in the step-by-step, if you are of age, a lil' Killians wouldn't hurt, helps keep the frustration level down
