can i get my truck aligned with a lift and 33's anywhere?
i'm putting a 3" suspension lift on this weekend, i just added 33" baja claws. will i be able to get an alignment done anywhere, or will not every place be able to accomodate my truck? any suggestions?
you should be able too anywhere. the only thing is i would call and ask them if they can accept the size tires you have on it. sometimes theres equipment cant handle that wide of a tire so you might have to just put the old ones back on.
Yep the local shop I work at does them fine. I originally thought I might not be able to but with 33" tires it doesn't seem like it affects much as it will still fit on most lifts.
Ya you should be able to get it aligned anywhere DONT PUT YOUR OLD TIRES BACK ON!! because if you put your oversized tires on after it will need to be aligned again so you would just be wasting your money.
Make sure you ask for the maximum amount of caster that they can put in. this will eliminate any potential death wobble problems that could come up down the road without max caster.
ORIGINAL: steve00ram360
unfortunately, i've called 4 places already, 3 said they can't accomodate the truck, one said i'd have to stop by so they can look at it. are there any off road shops that can do this without a problem in central NJ?
