Gauge Question. Hooking up Tach and a/f
Old Apr 14, 2006 | 07:38 PM
kroffty's Avatar
kroffty
Default Gauge Question. Hooking up Tach and a/f
I just got my Tach and Air fuel ratio gauges from Ebay. And I think I have them hooked up wrong. The tach works perfect from idle to 2500 rpm but will not go past
3000 rpm. I hooked the signal wire from the tach to the black wire with a white stripe on the coil. Should it go the other wire on the coil? I think it was green with a Orange stripe.
The A/F guage I hooked up to the grey wire on the o2 sensor . The one before the cat. and the guage stays pegged on LEAN. Should I hook it up the the O2 sensor
after the Cat?
Thanks for the Help!
96 dodge ram 1500
5.2L 4X4 5 speed
A/f guage
Tach
Old Apr 14, 2006 | 10:55 PM
kroffty's Avatar
kroffty
Default RE: Guage Question. Hooking up Tach and a/f
Well I mashed the long pedal on the right and got the tach up to 4000 rpm seems a little low but maybe its working.
I think I have the A/F gauge hooked up to the ground instead or the signal wire . I will mess with that later.
