Towing package...elec. problems!
Old Apr 19, 2006 | 12:30 PM
dalewoo's Avatar
dalewoo
Default Towing package...elec. problems!
I have the factory installed towing package. The relay for the trailer lights is working properly but I'm not getting power to the trailer lights. Is there a fuse somewhere? I can't find one.
I have a jumper installed now so whenever I hit the brakes, all trailer lights come on.
Any help is much appreciated!
Dale
Old Apr 19, 2006 | 03:11 PM
1500sport's Avatar
1500sport
Default RE: Towing package...elec. problems!
There should be a fuse in the fuse box under the hood. I had a problem with my wiring system not working the trailers lights properly. Took apart the plug and part of the wiring harness and found nothing wrong. Then started looking at the fuse box and found the bad one. Replaced it and bingo, everything was right again. The one I replace was one of the square block fuses which of course are a little more expensive then the little cheap ones.
