I'm New With Pictures!
Old Apr 20, 2006 | 07:00 PM
Socha_62's Avatar
Socha_62
Default RE: I'm New With Pictures!
I have a 2000W amp pushing my 2 Rockfords wired 2 ohm. They take the power NO PROBLEM and I've never felt the back of them getting hot at all. When I had them in my Jimmy with a Bandpass box facing backwords they TUMPED. They were almost as loud as my friends 3 10" Kicker L5's.
I guess I have brand loyalty, RockfordFosgate all the way!
And raise the back seat and put boxes under it. It sucks having 1/2 your back seat taken up, thats the only thing I hate and regret about it. But once you have subs and are use the the bass I dunno if I could go back to a stock system [&:]
Old Apr 20, 2006 | 07:44 PM
Substance's Avatar
Substance
How do i go about raising the backseat?
Old Apr 20, 2006 | 08:04 PM
crazy1snow's Avatar
crazy1snow
i wouldn't recommend lifting the back seat as you have to relocate the seat back brackets up higher on the back wall. unless you're prepared to do it or have some direct instructions i'd go with the two tens the fit perfectly under the back seat. just my opinion
if you don't want to use the backseat at all forget it and make a nice fiberglass enclosure that takes out the backseat. i didn't want to do that and with the already limited rear view i wanted to keep the back seat where it was.
Old Apr 21, 2006 | 12:29 PM
Chopper1's Avatar
Chopper1
Here is a link to raise the seat, depending on year. Shot has insight on this also. http://home.insightbb.com/~jbenner/Riser.htm
