headlight failure
Old Apr 20, 2006 | 03:53 AM
sacram's Avatar
sacram
Default headlight failure
long story but basically my passenger side headlight will not work on the low/normal beam, but on high beams it comes on fine. checked the wiring behind it and did not find any obivous problems. tried a new bulb in it and expierenced the exact same problems. checked all of the fuses and non were blown (kinda assumed this also given that the other headlight is still working and the brights are working) so where i'm at right now is i have no idea where the problem could be, can anyone help direct me in the correct direction to find this problem and maybe how to correct it?
Old Apr 20, 2006 | 03:54 AM
sacram's Avatar
sacram
Default RE: headlight failure
o btw i have a 97 1500 with 158xxx miles on it
Socha_62's Avatar
Socha_62
You have a multimeter? Of so check out that wiring and see if its getting power. That right there will tell you if its a bulb problem or what it is.
Old Apr 20, 2006 | 03:57 AM
sacram's Avatar
sacram
nah i dont have one...but i prbly can get my hands on one, i'm pretty sure its not the bulb though because i took the bulb from the working light and tried it, so its somewhere in the wiring
Old Apr 20, 2006 | 04:02 AM
shott8283's Avatar
shott8283
id shoot out the lowbeam 12V supply wire... make sure its getting juice... you notice your battery low or hard to start in the morning after sitting for a long time?
Old Apr 20, 2006 | 04:11 AM
sacram's Avatar
sacram
nah the battery is fine, the guy that sold me the truck though screwed me over so i had to put a new battery in it 3 months ago, he was running a much smaller battery that was suppossed to, so the battery is fine. but i will check that power supply
