code 0442 and sputtering
Old Apr 25, 2006 | 05:32 PM
ducktruck's Avatar
ducktruck
Default code 0442 and sputtering
As soon as I pulled out yesterday, my '01 5.9L ram started sputtering, hard. The check engine light was on and a code of 0442 came up when I did the "key trick."
From what I've read here, the two most likely things are a bad gas cap or EVAP canister (please correct me if I'm wrong). At least as far as the code goes, not sure about the sputtering.
The sputtering happened once in the past, but cleared up after running high test for a day. No check engine light that time though.
And there was no sputtering when I took it out just now (at least for the moment), but the light is still on. What's the recommended course of action?
Thanks for your help with this.
Old Apr 25, 2006 | 07:19 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: code 0442 and sputtering
Check out this thread: https://dodgeforum.com/m_449426/tm.htm
Old Apr 25, 2006 | 11:19 PM
sacram's Avatar
sacram
whats teh key method, my check engine light has been comeing on recently, but everytime i'm about to take it to my buddys shop to hook up the diagnosis machine or w/e the light goes off, i'd deffinately be interested in any way to check codes on the spot without having to buy a programmer or w/e
Old Apr 25, 2006 | 11:36 PM
The Burning Rom
ORIGINAL: sacram
Key method and code info here: http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm
Even if your light goes out, the code that was set should still be stored in the PCM for the next 51 start cycles. Your friend should still be able to read it with his diagnostic machine that way.
Old Apr 26, 2006 | 02:19 AM
blacklabel2469's Avatar
blacklabel2469
that code means " evaporative emission control system, small lead detected". that is straight from the haynes repair manual
Old Apr 26, 2006 | 03:04 PM
ducktruck's Avatar
ducktruck
Thanks, I think I found the problem. Two cracked hoses coming out of the "duty cycle solenoid," marked "34611 5/16."
I'll replace those and see what happens.
Old Apr 27, 2006 | 01:16 AM
ducktruck's Avatar
ducktruck
Okay, that did it. Thanks again.
How long does it usually take for the light to go off on its own? I disconnected the battery for instant gratification.
