Front Axles
Old Apr 27, 2006 | 11:34 PM
Dodgeramman's Avatar
Dodgeramman
Default Front Axles
Ok time for another dumb question from me. U-joints are going I figured that out, read hayes manual and it looks prudy simple. Remove the brakes, unbolt axle nut (46 mm or 1 11/16"), three hub-to-knuckle bolts (13mm or 9/16" 12 point) and pull off. Now my question is do I HAVE to take the axle out? If I have a press then I should not have to, I just don't want to ruin my seals. Know I don't have a torque wrench that goes to 175 ft lbs how do I know how much to tighten the nuts? On the big trucks we just tightened it down and then backed it off so it spun freely and the tightened it to the next cotter pin hole. Would this work on the ram?
Now to grease or not to grease that is my next question. Greaseable or not, are there different type of bearings in them now? I have done driveshafts and know about those friggin needle bearings and thought I read some where there is a new type out there.
Old Apr 27, 2006 | 11:42 PM
GOD RAM IT's Avatar
GOD RAM IT
Default RE: Front Axles
You dont have to take the axle nut off. you can leave it on and just unbolt the 3 wheel bearing bolts. and yes you do have to take it out.
Otherwise you'll be fighting yourself with the lack of room.
You should be fine with your seals. Ive had my axles out plenty of times and the seals are still good.
Old Apr 27, 2006 | 11:50 PM
The Burning Rom's Avatar
The Burning Rom
Another guide...probably better than the Haynes [>:]
http://www.pavementsucks.com/tech/hub.php
Go for a greaseable u-joint.
