Sway Arm
Old Apr 28, 2006 | 03:55 PM
kharding20's Avatar
kharding20
Default Sway Arm
The sway arm bushings on my dads 2001 Half Ton 4x4 Ram are shot and I was curious what size bushing I need. They are either 30mm or 32mm. Which size do I need, Thanks
Old Apr 28, 2006 | 08:47 PM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: Sway Arm
What size do you have? That's the one's you'll need :P.
Take a strip of paper or masking tape, find a fairly rust free part of the sway bar, wrap it around the bar, and make a mark where the paper meets the end...take that, compare it with a ruler, and find your mm...32mm is just a hair over 1 1/4 inches...30mm is under 1 1/4.
