compression tested
Old Apr 30, 2006 | 02:35 PM
TPSDODGE's Avatar
TPSDODGE
Default compression tested
I compression tested my 95 318 ram today and came up with 175 all the way across the board. Is that normal? I cant find the what
it should be stock or what the service limit is so i thought i would ask you guys. Any help would be apreciated
thanks tim
Old Apr 30, 2006 | 06:20 PM
TPSDODGE's Avatar
TPSDODGE
Default RE: compression tested
anybody
Old Apr 30, 2006 | 08:03 PM
fiveliterbtr's Avatar
fiveliterbtr
175 sounds about right...should be at least 100 psi, with all cylinders within 10% of each other...the reading is taken on the 3rd compression stroke...150-175 psi is a nicely sealed engine.
Old Apr 30, 2006 | 08:12 PM
TPSDODGE's Avatar
TPSDODGE
thank you very much. I found a fsm and downloaded it, and it said 100 minimum. I guess I was wondering what "new" was
because my engine has 170k on it. And i thought that 175 sounded a bit high
