Ignition? or what?
Old May 13, 2006 | 10:09 PM
fiveliterbtr's Avatar
fiveliterbtr
Default RE: Ignition? or what?
ORIGINAL: follybeachjrii
Did a injector test all were great.Whats left?
How did you check them?
Old May 16, 2006 | 06:27 PM
follybeachjrii's Avatar
follybeachjrii
It was the injector.......I went ahead and replaced all 8 of them.....Problem solved
Old May 17, 2006 | 06:39 PM
mavrik's Avatar
mavrik
GO THRU WHOLE TUNE UP AGAIN.....I'M BETTER YOU HAVE A BAD WIRE OR A SCREWED UP PLUG...
Old May 18, 2006 | 12:16 AM
follybeachjrii
1,686.00 BONES (Dollars) TO replace all 8 injectors and a few other little tid bits........So you all know
Good luck
Old May 18, 2006 | 12:33 AM
fiveliterbtr
That's why I asked how exactly you checked them...you can ohm them and read fine, but an amperage draw test while running would've been my next choice, as they heat up, one was probably drawing more amps, which would dump more fuel...but if replacing all 8 works for you, it works for me Glad it's fixed
