Spark Plugs??? Autolite 3923's
Old May 12, 2006 | 11:31 AM
hilliad's Avatar
hilliad
Default Spark Plugs??? Autolite 3923's
I have read alot on here about the Autolite 3923's. I currently run the AP5224's. What is the advantage of the 3923's?[&:]
Old May 12, 2006 | 01:33 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Spark Plugs??? Autolite 3923's
The 3923's are one temperature range cooler then the stock plug or the Autolite equivelent which is a 3924. This helps if you are having any issues with detonation (pinging).
Old May 12, 2006 | 01:35 PM
hilliad's Avatar
hilliad
Thanks for the info.
Old May 12, 2006 | 01:36 PM
hilliad's Avatar
hilliad
I assume you would gap them the same as the stock.
Old May 12, 2006 | 02:06 PM
Silver_Dodge
I gap them at .035-.038, a little tighter than spec. Seemed to perform better like that.
