Antifreeze leak
Old May 19, 2006 | 07:31 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Default Antifreeze leak
Anybody have issue of leaking anitfreeze in 50 degree weather otherwise when warm outside or cold when its in between a small drip at turnoff engine. Other than that never had anymajor non self incurred issues.
Old May 19, 2006 | 07:56 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Antifreeze leak
Where is the drip? Front of the motor? Ahead of the motor? One side or the other? Can you see it running down the engine anywhere?
Old May 22, 2006 | 03:53 PM
DuranguenzeRam
its in the front directly under the water pump but that was replaced and no leaking or anything had pump off might as well replace. Its only a few days of the week its not a constant drip by any means also replaced the temperature sensor while i did the water pump. ALSO now developed an oil leak by the front of the hood looks like from a part of the suspension. its a drop everytime i park. nothing major other than that the truck is the best ive ever owned
