Questional repairs part 2 I was Screwed
Old May 20, 2006 | 04:25 PM
rydog2624's Avatar
rydog2624
Default Questional repairs part 2 I was Screwed
Alrgiht so this is continuing my pervious post, so after paying the 300 i go to the dmv and get my plates so im happy. I go out with some buddies to hang out so i get back and go to sleep. When im taking some clothes in the morning to the dry cleaners, the check engine light is on agian and its the same code. Im so pissed, i did fill some gas up the day before so just for safe messures i tightened the cap and reset the battery. If the light turns back on im gona take the truck down there and im going to make them do any repairs neccesary and im not paying a dime!!! My ammo is that they cretified me for plates and the code came back on so he lied by certifing the truck and they can get there license taken away lol What do u guys think ?
Old May 20, 2006 | 10:18 PM
miknwv's Avatar
miknwv
Default RE: Questional repairs part 2 I was Screwed
Not sure how it is in your state but here you CAN pass inspection with a C/E light on. You can't pass inspection if the airbag light is on though.
Old May 20, 2006 | 11:19 PM
shott8283's Avatar
shott8283
Here in NY you can't. As far as I know its either an auto failure or a wicked fine tooth comb inspection if the CEL is on.
Old May 21, 2006 | 12:00 AM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: shott8283
It's the same way here in WI...in the areas that have emissions inspection, which is pretty much just Milwaukee. From what I'm told, they'll even question it if you have a code stored in memory (with the CEL off).
Old May 25, 2006 | 01:00 PM
SST_Ram's Avatar
SST_Ram
You can pass !?!?!??!? In NJ, 96 and up, they jack your computer. You will fail for a CEL or an active failure code, and if the computer didn't do all of the self checks ( OBD II readiness test ) in which they print it out with your inspection results....If you reset the the computer before inspection, all your systems have to reset. Example: Heated O2 test - not ready. That will get you a failure.
