Tranny problems!!!!!
Old May 25, 2006 | 06:16 PM
sixerp's Avatar
sixerp
Default Tranny problems!!!!!
Yesterday, while coming home from school my tranny and check engine light came on. Pulling off from a stop sign my truck drove like it was in overdrive, then the light came on. It did it again, so I put the gear in 2 and it drove fine until I stopped again, and the process started over again. So I went to Cottman transmission, they said that I have a couple of sensors gone bad and it may cost about $500.00 to fix also they said that they would need to drop my tranny pan to see if there is any metal... Well we all know what's next, he said that I may need to have my tranny replaced, somehow I knew he would say that. cost to replace $ 1800.00. If anyone out there has any suggestions,comments, or experience with this problem please help!!!
Old May 25, 2006 | 06:46 PM
mopowar's Avatar
mopowar
Default RE: Tranny problems!!!!!
When you are dealing with nationwide transmission shops, you might want to get a second opinion. Unless you have diagnosed the problem yourself and tell them what to do, they have a tendency to see bigger problems than really exist. This includes dealerships.
Old May 25, 2006 | 07:27 PM
EMRJPV's Avatar
EMRJPV
Get the codes read then check your VSS (speed sensor on the tranny) mine went bad and had the same experiences.
Old May 25, 2006 | 09:35 PM
xtech's Avatar
xtech
When I worked at the dealership I also replaced alot of gov. pressure sensors. Sometimes they can be tricky diagnose. I have seen the voltage reading on the sensor to low but not out of the PCM's range of reading. No check engine light but still take off in high gear. I'd be sure to get the codes.
Old Jun 5, 2006 | 06:40 PM
sixerp's Avatar
sixerp
Update on my tranny problems! I finally found a honest tranny shop, go figure.. before I could finish telling the owner of the shop, by the way who is the mechanic, what my problems where he named everything the guys posted on my thread. I dropped the truck off in the am and it was ready by noon... after replacing the sensors my truck runs as good as new. cost for repair was $ 380.00. thanks guys for all of your help!!
Old Jun 6, 2006 | 01:55 AM
BIGSEXY's Avatar
BIGSEXY
All I have to say is....WELCOME TO THE CLUB!!
