trans. fluid
Old May 27, 2006 | 12:16 PM
rico's Avatar
rico
Default trans. fluid
My quistion is if you get the tranny rebuild with a after market kit do you still have to use the atf + 4 fluid or can u use the dextron 3 ?
2000 dodge 4x4 360 46re
Old May 27, 2006 | 03:15 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: trans. fluid
Yes...you still have to use ATF+4. Or you could use a synthetic alternative like Amsoil.
Old Jun 3, 2006 | 06:19 PM
badram1500's Avatar
badram1500
Valvoline now has an atf+4. Full synthetic. Only about 4 or 5 bucks per quart instead of the 8-9 the stealership is charging up here. Found it at CarQuest.
