same way with dodge, one side is round, the other is square.. it should just slide one way and pull off.. .. it needs to be at about a 30-45 degree angle to pull up and outwards
On my 01, just remove the cables...45 degree angle as said...pass. side pull away from the truck...drivers side then slides off the "post" towards the pass. side...and done. It's not as heavy as I thought it would be, but the size of it makes it a bit akward.
